I am in need of some help with my Sinistar....
First off, I am installing a JROK into a dedicated Sinistar cockpit. Trying to leave everything original if the next owner wants to convert it back.
Anyway, I was hoping someone could shed some light on how the joystick works and if there are any test you can do on it. I wired is up to the colors from
3J2: Player Panel
1 - Up-Down Switch A1 (Orn-Brn)
2 - Up-Down Switch B1 (Orn-Red)
3 - Up-Down Switch C1 (Orn)
4 - Up-Down Direction 1 (Orn-Yel)
5 - Righ-Left Switch A1 (Orn-Grn)
6 - Righ-Left Switch B1 (Orn-Blu)
7 - Key
8 - Righ-Left Switch C1 (Orn-Gry)
9 - Righ-Left Direction 1 (Orn-Wht)
10 - Fire 1 (Red-Blk)
11 - Sinibomb 1 (Red-Brn)
12 - N/C
13 - 1 Player Start (Yel-Grn)
14 - 2 Player Start (Yel-Blu)*
15 - Ground (Blk)
*2 Player start not connected in cockpit games.
to match up to the attached wiring from the instructions (see picture). At this time, I only get motion in the down left direction, but it can be modified to left as well.
Is it possibly a problem with the joystick (I don't know if it is good), or did I just mess up wiring it last night (really late).
Thank you
Brian
3J2: Player Panel
7 - Key
12 - N/C
15 - Ground (Blk)
Thank you
Brian
