I have two of these side by side,swaped hdd,with same result,also switched PCb boards and it's narrowed down to the PCb itself,also cleaned the legs on the boot rom and still has same result,when powered led4 turns green then blinks and then goes off and led2&3 blink simultaneous on PCb board,tested power supply and all voltages are correct coming out of power supply so any ideas?
