wolfeel
I need help setting up Data I/O 29B with UniPak 2B to my computer using XP.
1) I made the connecting cable following this link: http://retroclinic.com/leopardcats/dio/dataioserial.htm
2) I installed the needed stuff from the following link: http://www.mikesarcade.com/arcade/promlink.html
3) Tried to open pl.exe and this came up:
"C
OCUME~1\Kevin\Deskto\DOWNLO~1\pl.exe
The system cannot open COM2 port requested by the application. Chose 'Close" to terminate the application." - not sure how to turn off smiles.
is should be : D
4) If I chose "Close" it of course closes the app. If I chose "Ignore" PROMlink 6.10 opens up with the following prompt: "Error reading setup file PL.SET- defaults installed"
Can anyone help?
"C
Can anyone help?
