DamnRandall
I've got a Point Blank 2 board that I'm trying to install into my Police Trainer cabinet. I'd like to be able to switch back and forth, so I created an adapter that the Happ guns will plug into on the Point Blank 2 board. I followed the notes detailing which pins do what.
I do currently have an issue with pin #22 on the parts side. As I was soldering wire to it, the tracing pulled up, so I currently have one of those circuit writer silver pens drying on it right now. Before that, though, I tried testing it out on the 2 Player side, but the gun doesn't seem to work.
http://i.imgur.com/YDEVi.jpg
I went into the test mode to try to calibrate the one connected gun, but it wasn't registering. I went into the switch test to see if the gun was even showing up, and it doesn't even detect the trigger being squeezed.
I took my multimeter to make sure the gun was getting power, and I do show +5vDC on the red wire.
Any ideas? Also, any recommendations as to where to attach the wire for the player 1 trigger?
