Need help ID'ing Race Drivin Chassis
DanoND
Bismarck, North Dakota
I have the tube, but no chassis. This is in a Race Drivin' cockpit (not the compact upright with the bench).
Tube ID is R-A63ADG25X
I'm having a hard time discerning whether Race Drivin' cockpit is a standard or medium resolution game, and what chassis/monitor I should be shopping for.
Thanks for the help guys.
my race drivin had a k8000 yes 8000 series in it, and im pretty sure that was original.
Your best option is to find an original chassis versis total monitor replacement
... The steering feedback motor makes a ton of "electrical noise" and most other non original monitors dont filter it out like the original one did. Therefore using a non original monitor will work, but you will get some wicheked "snow" in the pic. The last one i had i tried using a nanao put line filters on it, lots of rf chokes on the motor wires and video wires and it still looked like a snowstorm during turns.. My only option was to temporarily unplug the motor board so i lost feedback steering but lost the snow at least.
Id get the numbers off the yoke and ohm it, get a pic of what you have left, post it here, pm chad the arcade cup dude to make sure what you have before you start your hunt.
Might be 8000, but I did verify that the 25" K7000 used that tube number. Not sure if the 8000 did...
If he could grab a picture of the frame we could probably tell then.
Or look for any labeling with identifying numbers on or around the frame.
If a replacement chassis is the option, then the yoke also becomes a question....does a medium res K7000, K8000, U5000 use the same yoke ?
