Need help identifying two pcb's...
mastercello
Hochdorf, Luzern, Switzerland
...seems the first one is a falcon board (2x18Pin).
I would like to make a Jamma adapter for both of it.
But without pinout it is a little bit dificult for me.
Also ROMIdent marked both of them as unknown!
Any help is very appreciated - thanks a lot.
Can't tell where the 12V goes, but I would guess the Falcon board most likely uses the Falcon pinout. It has the first 3 pins tied together (ground), and pin 9 looks like it ties into a bus that goes around the board. On the Falcon pinout, that's +5, so that makes sense, since it has to feed all the chips. (you would want to double check that of course...finding a pinout for a particular TTL chip and figuring out where +5 is on that chip should be able to let you find it on the edge connector). I'm not sure what the other one is, but it almost looks Nintendo-ish. It's got the grounds in the right spot, and that 2nd group of 2 from the left might be +5 (again, use the same method mentioned above) and it has an I8035 chip, which is what DK and DK Jr use, so it might be a bootleg of one of those (I haven't seen any that looked like that though).
@crazykongfan - All Falcon Boards have the same pinout?
@modessitt - Video Hustler? Never heard of it - is there a pinout available?
@kane086 - thanks, do you have a pinout for it? Or can you take a picture of the jamma harness for me?
Thanks a lot "boys"
Thanks - can you provide me with a picture of your pcb or tell me what eproms i am missing?
The 2 on the left are the GFX1 data and the right is the sound data, I have them dumped here somewhere, I'll get back to you on that.
______________
OK, from MAME set Donkey Kong Jr. (bootleg) - dkongjrb.zip
Board Location 7E - dkjr10 - CRC - adc11322
Board Location 7G - v_3na.bin - CRC - a95c4c63
Board Location 7N - c_3h.bin - CRC - 715da5f8
All 2732 ROMs.
