Need Help Identifying Kagi Monitor Video Connector
mercurygold
Maryland
I purchased a Kagi 19 inch monitor (KB240162) a few weeks ago. I have tested it with a CRT pattern generator hooked up using probes and it works great. But I am having trouble identifying the exact type of connector I need to buy to hook it up to my arcade MAME computer.
Here is a stock photo of the Kagi chassis and 6-pin video connector from here:
https://www.arcadepartsandrepair.co.../Kagi-19-inch-13-inch-KB240162-Top-scaled.jpg
Here is my board and a picture of the pins:
The connector next to it is very similar but uses 4 pins instead of 6. Here is a picture of the bottom of the 4 pin connector:
Does anyone know what type of connector this is and where I could buy the 6 pin version shown in the first picture?
Even if I could buy individual connectors that would fit each of the pins separately would be help if anyone has any ideas on this as an alternate solution.
This pins are spaced at .170 inches (4.32 mm) disregarding the HD pin with the white wire which has a larger offset from the others.
The pin diameter is .064 inches (1.63 mm)
Any guidance would be greatly appreciated. Thanks!
Yep. That looks like what I'm looking for. Thank you! I'm putting in my order now...
