Need help identifying chassis and vertical roll issue with House of Dead 2 upright
Nanao 2932 apparently, 31 KHz/VGA only
the V. Hold doesn't appear to be on the remote board, and your first picture is out of focus where the adjustments are in the upper right corner. Nanao was a little silly like that where some of the adjustments are on the deflection board instead. but those adjustments should be accessible through the slot in the frame "under" the tube usually, so you may just need to pull the whole tube shelf out to get at it. I don't remember how HOTD2 is laid out off hand now. good luck
