Need Help - Golden Tee Board Swap
jjoravec
Donor 2013
UNITED STATES, Virginia
I have a working Golden Tee 2005 with a Red board. I picked up a Golden Tee Complete Green Board and power supply. What all do I need to swap the Red Board with the Green Board? Can I just swap the board and Power supply? Is everything else in the cabinet the same (wire harness. etc.)?
To Swap a Red For a Green. You remove the Red board, Remove the ATX power Supply.
Install Green Board, Install a New Arcade Power Supply Connect that to the JAMMA harness and wire that to the 110 volt. Also you should have a Power Bypass cable for the Green board. It connects from the Power Supply to the Two 4 pin Molex on the Green board, and the Hard Drive.
All other Wires in the Harness are the same.
