Need help fixing this RARE game
copyimitation
Ohio
So I picked up strength testing game, that seems to be super rare. It's called "Crusher" made by Bundra Games made in 1991. All the lights come on and the sound seems to work, but the actual game doesn't play. You are supposed to squeeze the can and LEDs on the left will tell you your score. But nothing happens when you squeeze it, and I've even tried to manually trigger the switches. I don't have any machines with this kind of switch, what is it called? Any help is much appreciated 😁
I would bust out my trusty dusty multimeter
you want to test the switch to see if its broken
put the multimeter on the sound option which means when you touch the two probes together you will get a sound and use that to test the switch
hopefully the switch is bad
looks like a coin mech switch to me but maybe it has some sort of roller or whatever modification on the little arm there to make the trigger happen
good luck
cool machine. I don't wish I had one but so what
