need help finding this kit
rony2211
weaverville, North Carolina
need a cap kit and Horizontal width coil for a sharp image med rez kt2602m. only thing is this is not a sharp image chassis. its a kortex? i checked bob roberts and cant find it anybody have any clue were to fined these parts Ron
well.... what you can do it pull the chassie out... set it down on a table... use a marker.. and look at every cap see what the values are uf & v write it down, then use yer maker to put a mark on the top of the cap so you know that you allredy wrote that one down. do this for every cap. then goto your local radio shack and buy the caps or buy a couple of thoes grab bags there that have like 20caps in it. or order online at theshack.com or mouser.com ...
now the way that caps go is you MUST match the 'uf' up correctly.. but for the 'v' you can use any # higher then the listed 'v' value
using a higher 'v' value only provides more protection and is ok and perfectly acceptable
but DO NOT use a 'v' lower then your listed value
