need help after moving cab
rony2211
weaverville, North Carolina
hello i searched around the forums before i posted with no luck . im very new to arcade cabs but work on snack and drink mach .here is my prob i bought a few arcade cabs that all worked before i moved them know the tekken cab powers on but only has a few color stripes to the left of the monitor like red,yellow,blue no sound nothing i looked to see if anything was loose did not see anything? im pretty sure its a jamma kit if that helps thanks
Ron
Disconnect the board connector and reconnect it, see if that does anything. Pics will help immensely.
Hehe - I just replied to your post over at NintendoAge... But, you gave more information here - it does not play at all, just displays that pattern. Do any of the buttons do anything? Is it a defined pattern on the screen? If it filled the whole screen I'd be inclined to suggest that it might be in test mode - there is usually a switch inside the coin door for that. But, without a picture it's hard to say.
-Ian
