Need for Speed U restore questions. Monitor, Power supply, Nytric" I/O
So I am hoping to restore a need for speed underground, but I am running into a few snags. Went into it knowing the monitor was shot. I looked over the old one after I took it out and I can only guess leakage ruined the WG chassis.
I have a 27 inch crt TV I took the back off and will fit perfectly in the old cabinet But it does not have a vga connector, just s cable and audio jacks. Is there an "easy" solution to attaching the tv to the arcade machine... That will be one problem down.
Second problem, The 24 v power supply that runs the force feedback motor. It is only kicking out like 3 volts, and even the red light does not go on, so that will need to be replaced. Problem is, they are not exactly cheap. Other PS were not so bad, but this one is around 50 bucks. I did notice a switching power supply 24 v 5 amps, for LED's for a fraction of the cost but their front wiring looks like this. Do not want to wreck anything, but wondering if anyone else tried something like that. Not a big deal right now, just after I bought the machine, life happens and drained my bank account more than I hoped.
On to the last problem, The shifter does not work. It s connected and even the e brake is not working that is next to the shifter. Another thread pointed me to the nytric board and faulty chips. How does one go about getting new chips to replace them or fix those,.. I am total lost with that.
Pictures are of the Led PS, Old monitor chassis vga, and new monitor with the s cable.
