Need exact Mario Bros Widebody Base Dimensions
Phetishboy
Avon, Minnesota
I need to know the outside measurements and the distance the front baseboard sits behind the kick panel. Thanks.
Anyone at all? Was gonna cut the base boards tonight, but I don't think the ones on my WB are original. Still need the measurements. Thanks!
I just made a new base myself (mine had 2X4's nailed to the bottom, pretty) and the measurements I came up with by measuring the old marks on the bottom were 24 3/4" X 25 3/4" . The base sits back from the front edge about an inch but I can get you a more specific measurement in a bit if you'd like.
Front edge of the floor? Or front edge of the kickplate? My kickplate is currently removed to be vinyled.
Yeah, the front edge of the kick plate. That's actually the reason I'm not 100% on the precise measurement on mine, because my kick plate is removed for vinyling as well.
Ok I measured it and it measures 1 1/8" from the front of the kickplate. I went ahead and measured all my Nintendo cabs and they were all 1 1/8" including Punch-out!!
Ah, it's alright man, I was mostly hungover and hungry anyway, ha. I'm actually working on a drawing of the widebody base with all the dimensions and cuts and I'll probably post it here as I see this question come up quite a bit. Hopefully it will be helpful for someone down the road.
