Need DK vertical monitor mount hole dimensions on cab sides
danpiraino1971
Donor 2014
Bridgeport, New York
I have a nintendo cab that Im converting to Double DK. It has a horizontal mount monitor in it. I have the vertical brackets but there are no holes in the cabinet for the rear mount. I need the mounting hole locations. (Two on each side). If you can help that would be great.
Thanks,
Dan
it was a popeye cab if the vertical monitor hole are not there. the hole should be 18" down from the top and 4 1/4" from the back.
Ok but there's two holes there. That dimension is only for one hole. Didn't they just make VS cabinets. There's a model number on the back of it. Its MGS-UP-US.
On mine, the upper hole is 4 7/8" from the rear, and 17 3/32" from the top (without t-molding).
The lower is 4 1/4" from the rear, and 18" from the top.
The conversions had new serial number plates. On my DK cab, the original DK plate was underneath the VS plate.
