Need bracket measurements for Konami marquee
Johnny Cutt
Donor 4 years: 2011, 2015, 2019, 2023
Metro Detroit, Michigan
I've seen a handful of people on here in need of top and bottom brackets for their Konami cabs.
I know the Sunset Riders and TMNT cabs both use top and bottom brackets, but the Simpsons cab seems to only use a bottom bracket, with the top slot for the marquee notched into the actual wood of the underside of the top of the cab.
For example see this thread:
http://forums.arcade-museum.com/showthread.php?t=249474
Is anyone willing to give the exact dimensions of there brackets so we can fabricate some?
I know the width is 27" wide, but can someone give the exact heights of the two 'lips' so we can get as close to the original as possible?
Lastly, does anyone know if the bottom bracket used for Simpsons is in anyway different from the bottom bracket used for TMNT, etc?
While we're at it, can someone give the exact dimensions of a true Konami marquee? I have a repro, but I don't want to rely on it's cut to be sure.
I am also looking for the bottom bracket, my cab is missing this piece as well
