modessitt
I don't have the fancy version.
I need someone who can take it out of the case it's in, and check where the wiring goes in on the back left, and tell me exactly which order the wires colors plug onto the pins in there. I had a couple that came off, and I thought I got them back on the right spot, but my rejuvenator has been acting funny lately.
I don't know why they used such a lame way to connect the wires to the board inside. Couldn't they have made a connector, instead of using individual wires with their own little female connector on the end of each, slid over a vertical male pin?
Considering it's a pain in the ass to take it completely apart (with the main selector switch going through three different boards), I plan to just direct solder each wire to the bottom of that board so they can't come loose again.
Unfortunately, the schematics in the Instruction Manual don't detail this.
If you are barely tech-savvy enough to know how to use it, you may not be the best person to do this. I wouldn't want you to accidentally damage yours in an attempt to help me fix mine.
There are 3 different rows - of varying length - if I recall correctly. If you can do this, please list them left to right (by row) as you look in from the side...
