need an expert opinion(it's the X-Men sound issue and yes I know)
darkcat1
Winston, Georgia
I bought a slightly broken four player X-men conversion as my first machine and I'm trying to fix it to play Beat'em Ups(sorry that's what I want rather than wiring it back to gauntlet...yell at me now if you wish). My friend with a two player machine tested the board and got no sound out of it...he also couldn't get the one player working.
Upon getting around to visually inspecting the board I found some rust around the test mode switch and some corrosion(like an old battery) on one side of the sound chip. The capacitors did look good to me and I'm a PC repair guy(so I should know my way around a motherboard). They also were not bulging or leaking but the black plastic around them was flaking off like mad.(also the sound did work breifly before I bought it)
I'm thinking I'm screwed or at least this is not something a PC parts changer like me can fix so now to the questions:
1. I do think I'm out of luck but I have to ask: does this sound fixable?
2. If so who might I go to? I don't know of anyone who would attempt a repair on this board(I think I site I saw said you could try recapping them)
there is a thread on this, the caps on the little board need to be replaced (its under the black stuff thats flaking off).
but you want to address the player 1 controls issue, there could be a bad resister network or ic chip.
If the caps on the sound IC are so bad they've leaked onto the main board, holy crap, I didn't think they had enough electrolyte to actually do that...
...so I think your corrosion is coming from somewhere else. Pictures pictures pictures! What does it look like? How does the sound IC look?
Bulging and leaking caps is predominantly a modern problem, on arcade gear the bad caps look indentical to the good caps, you cant tell by eye if the ESR is through the roof.
yes I know I read alot before and after posting this(even found the guy who will recap it for $150). I just wanted an opinion of someone more expert than me if this looked fixable at all. I took pictures of the side with the corrosion(I've tried cleaning it with canned air but haven't hooked it back up to anything) and even though it looks abit like a recapped on from the other thread there are still flecks of black on the tops which makes me suspect that it's original rather than fixed(before). Also note that I haven't tried the external audio but when I read about this issue and saw this side of the chip it worried me to death.(look at those contacts...)
Also for a few more pictures:
http://s1142.photobucket.com/albums/n604/darkcat12/
also I'm nowhere near good enough to try recapping it myself...
