need a williams 50/60 C 135 RPM motor
LUCKYMAN
Clifton Heights, Pennsylvania
I figured id post in this section to other then the WTB section..
Anyone here have a williams 50/60 C 135 rpm motor? I need it for a williams sniper im restoring at the moment.. I can get one, but id like to see if i can get one here cheaper...
Luckyman,
Have you posted under wanted on Mr. Pinball?
OHEMIO
Luckyman
That's what I usually do first and it does the trick. Is the motor riveted? Mine was for the SAMI and putting it back together was interesting I had to modify the brackets to accomidate the nuts and threaded rod.
I always take good pics with my iPhone as I tear down.
Big day today here the Panzers heading downstairs. Along with the MAME and the Midway Cobra Shuffle. If the shuffle sells I'll simply tear it down and carry it back up if or when somebody buys it.
Have a good day sir...
OHEMIO
yeah its rivited..one of the sproket rods is bent so its kinda "wobbling" as it turns , but it does turn the gears. soooo... im gonna just gonna try it when im done cleaning this thing and see if it works or not
#10 T-Rod - Nuts, Washer, lock washer.
That's what I used after I drilled out the rivets on the SAMI to tear the motor down.
OHEMIO
This is good news...
I'm glad you were able to get that up and running...always a point of concern the old motors. I chose to tear them down and clean them. My Target Alpha would not be running today if I hadn't done so.
OHEMIO
