need a vertial monitor mount for a Taito cab & other items asap
dj dns
Donor 2015
Dallas, Georgia
Need a vertial monitor mount for a Taito style cabinet (qix). Also need a Galaga cabinet to jamma pcb adapter. Looking for a Working Naomi 2 cpu
I have that mount that I took out of a Jungle King. I thought that was only for horizontal mounting. I will have to check today. The one I had in my pervious Qix cab was different than that one. Thanks for the link I that will be great if I can use it to mount vertical. I need to really get this machine finished by the weekend.
Yes, that mount works in either orientation. It is a perfect square, so you can switch a monitor from horizontal to vertical (and vice versa) simply by disconnecting and unbolting the monitor frame, pull it out, rotate 90 degrees, put it back in, and rebolt and reconnect...
yes that is the mount. The cab design will determine what frame will fit in there though. Some taito cabs have a plastic cover to accommodate the corner of a monitor frame sticking out beyond the back door. Some do not. So depending on the style of back door on your cab and the type of monitor frame you are trying to get in there, it may or may not fit.
That mount will work in both directions, however, you may have an issue with the back door not being able to close depending on the frame in your monitor. I rotated a monitor in a Jungle Hunt cab and had that problem. However, my Front Line with also has a vertical mount has no issues with clearance of the back door.
