Need a Taito back door with plastic monitor shroud..
local413
Longmeadow, Massachusetts
I'm in Massachusetts.. Will drive a an hour or so for the right door.
So i've installed a new wells monitor in my Frontline and wasn't paying attention to how much room i had once the back door was closed... :(
So, I could try and retro fit the new monitor to a vertical chassis.. or I could just happen to find a taito back door with the plastic backing that allows the chassis to stick out..
Figured I'd ask here if anyone might have one.. I'll also give you the door from the frontline if you can swap doors from a game that may not need the shroud..
Mylstar has a Taito back door "bubble" on his website if you want to go that route....
http://www.videogameparts.com/product.sc?productId=506&categoryId=48
Most of the doors with the bubble that I've seen look like they were just a standard door that an OP cut a hole in and place the plastic monitor cover over. Most likely when they swapped in a non original monitor. If I were you I'd just buy the part from Mylstar and save the time driving to get a door. Plus I bet you cut a better hole than the ones I've seen.
Awesome
Thanks guys! That's exactly what I need.. It would be cheaper and less work to just swap frames.. But I kinda like this idea better :)
plus it's nos! Ha
