Need a rebuild kit for Midway 90421 medium power supply
smalltownguy2
Donor 2013
Osceola, Wisconsin
I need a rebuild kit (caps, diodes, fuse, xsistors, etc) for the Midway Medium Power Supply found in my Super Pac cocktail.
Board ID is A082-90421-B000. Otherwise known as the Midway 90421.
Before I take the time to gather together my own part numbers and build my own kit, I thought I'd ask here.
Thanks in advance!
Bob Roberts caps are junk.
security has it handled so well he gets people to MAKE certain rated caps for him. ;)
Thanks in advance!
i don't think even BR ever made the kit for the 90421 because it has two axial caps that are impossible to come by. i make the 25,000uf 30v axial and i am working on making the 40,000uf in a snap cap with special eyelets on them and all are 105c. it would have eyelets like the pinball boards to make it easier to solder wire to and they are the same ones i make for all my pinball kits. its going to be another month before i have them back in stock but that 90421 is on my list to complete on this round of axials and snap caps that i am in the process of making.
so yes i can make the cap kit and the full rebuild kit for that 90421 and the 90427 (both the same pcb but the 90427 is populated slightly different). let me know if you need anything.
BTW: 32,000uf 16v is the largest axial cap i can make which is for the condor power supply that exidy uses.
PM Sent! :)
