Need a pic of a Sea Wolf Step
Phetishboy
Avon, Minnesota
From the underside. I have a few pieces missing and I am wondering what they should look like. I already built the feet posts for the leg levelers. Also need to know what was originally on the top side. Rubber matting, diamond plate steel, fine rugs from Persia? Thanks.
Mr. GorfChampion of Altura fame. I thought his does have the step??
So does mine. I bought his Extra Sea Wolf. He repainted the step that came with this cabinet, but it's missing a bunch of stuff from underneath. He was using some removable carpeted blocks to level the front of the step out as the built in leveler posts were missing. I replaced those posts but now I would like to replace the rest of the missing supports. I can see where several supports have been removed. He also stuck on a self stick tile to the top, and I wanna refurbish it with something a little closer to the original material.
Phet, c'mon man, you know you can hit me up directly for help. :) First, see my sketchup model. That will show you with pretty accurate measurements what should be underneath - at least what is underneath on the front half of the step.
The step is covered with that corrugated rubber flooring that you can get at Home Depot or Lowes in the flooring dept (I just picked some up 2 days ago). I think it was also used on the Pole Position cockpit too (based on seeing it in a red baron cockpit which is very similar).
I am in the process of moving my games back into the newly carpeted game room. I will try to remember to lay the SW down and get a shot of the underside for you. Feel free to bug me if I forget! And if you aren't quite sure what I'm talking about with the corrugated flooring, let me know and I'll also take a picture of that.
You're the best Jeff. I would love that. My leveler posts turned out pretty hot. I snap a pic and see how close to the originals I was.
