DarrenF
I've got a Wms sound board (the newer, square type) and it seems to be working (it's making sounds, alright), but just not the correct sounds. I don't have a known-working sound board, so I'm unable to be certain that the problem isn't on the ROM board (or the CPU board, for that matter).
Can someone with a working system check the following and let me know what they should be? (high, low, high-pulsing-low, or low-pulsing-high)
1) During attract mode, when it's making no sounds: at the 10J3 connector, pins 2-9 (assume these will all be steady.)
2) During test mode, with "SOUND LINE 1" mode activated: same location @ pins (assume at least 1 pin will be pulsing here.)
Thanks!
Thanks!
