Need a little help
mikdawg
Lowell, Indiana
I am wiring my first cabinet and I fired it up last night. I have sound and can play the game but I have no power to my monitor. I have the monitor hooked up to the iso transformer and I have the iso tansformer hooked up to my switching power supply (where the cord somes in). I assume that is not the right spot? How do I hook up the iso transformer?
Thanks for the help.
While not the best setup, that should've worked. Do you have the AC in hooked up to the primary of the iso and the monitor AC hooked to the secondary?
Do you know the monitor was working prior to the rewire?
I figured out that I had the iso trans wire in backwards. So I rewired it but now i blew out my on/off switch. So I am assuming that something is not grounded? Yes the monitor worked before putting it into the new cab. I think I need to invest in a power distributer.
