Fudd Active member VAPS Joined Jun 5, 2006 Messages 2,382 Reaction score 13 Location Kalamazoo, Michigan Nov 20, 2009 #1 Do you have to discharge to remove the neckboard? i just need to change out the purity rings and dont want to discharge if i dont have to.
modessitt Volunteer: Encyclopedia Submission Moderator VAPS Joined Mar 22, 2007 Messages 33,414 Reaction score 325 Location Austin, Texas Nov 20, 2009 #2 No. You shouldn't get shocked unless the neck is cracked. Obviously, it needs to be shut off. If you're worried, just touch the DAG wire to the neck pins...
Peale Active member VAPS Joined Sep 1, 2003 Messages 3,469 Reaction score 15 Location Brattleboro, Vermont Nov 20, 2009 #3 If the neck is cracked there shouldn't be any charge in the tube at all.
