A buddy recently gave me a G07 that looks incredible, zero burn at all. But it has one BIG problem - one of the pins on the neck is broken off, and a couple others are bent over. Is this trash, or is there a way to attach a new pin? The neck board socket looks fine, I thought if I could find the right diameter pin, I could cut a piece to fit the neck board socket and have it stick out a little so that once it's in place it would contact the broken pin, but I'm not sure if that will work. Any suggestions?
