JoJoRockets52
Cabinet is a conversion from what appears to be a Mortal Kombat 1 Cabinet.
Currently all buttons and joysticks work (using 49 way midway sticks will also include an extra) but the 4th Player joystick is missing the right restrictor grommet so it is loose (can be ordered online). Coin door is missing lock, but can just be replaced with a normal barrel jack. PCB is currently set to free play. Coin mech may or may not be working completely.
PCB was recently converted from using the old hard drive (will still be included) with a compact flash kit which will prevent issues due to the aging hard drive.
The monitor/sound all work, but the monitor is dim, but playable. Monitor has not been serviced in a long while so may just need a cap kit.
Currently it is in a basement and will required multiple people to help move.
