Nba showtime/blitz 2000 sportstation board FS
ShacklersRevenge
Massachusetts
Rating - 80%
4   1   0
Is currently in my game. It will reboot sometimes, other times it doesn't. Friends and I can play several games and other times it will reboot after a few games. I don't know anything about repairs for boards so..It does have all the fans and the games do work
I do know these boards are just about impossible to find unless you just spring for the whole game itself. It took months of romancing to get this board from an operator that had it tucked away in his warehouse for years.
B/o for the board, please no stupid offers as I will just keep it.
I have one of these. I'm inclined to believe that the reset problem is more than likely attributed to a failing hard drive. what versions are all your games? (should say on the chips, but it's good enough that you can get into Test Mode too I suppose)
I would be interested in anyone that can hook me up with a solid hard drive. I bought one on here, because my old one would not even boot to the game itself, just run demos. The hard drive I have now atleast lets you play games, so yeah, I think it's the hard drive too
Thanks, James
been looking for this board to swap out my Gauntlet Dark Legacy.....Correct me if I'm wrong and I believe I am, I would also need the Sports Station Hard Drive correct, not just the board?
You need HD, and the Video Card is differant, and the joystick wiring is different and by that I mean if you have the 49 Way sticks they won't simply swap. 8 Ways will but not the 49 way. It's not that straight forward of a swap but it always gets mistaken for one.
I have a dedicated showtime cab.....would this be just a board + HD swap? will a HD fix the probs he's having, or will i be opening up a moneypit?
well, after getting a tip from someone that they had the same style board and same reset problems, he said to lay it down and not vertical.
Since he has done that he has not had one reset.
I just put mine flat as well, ran it for over 12 hours, no resets!
Thanks! James
