swayze2
I almost have my new pin in the 99% complete range. I gave it a test run tonight and now the upper flipper is dead. Would this need a new coil? It seems rare the coil would be dead. Searching the manual now. Any ideas KLOVERS?
also check the wiring to the flipper switch. the upper flipper is on the shorter of the two switches on the right side. Also the flipper board in the cabinet has an LED that lights up when the flipper switch is pressed. Make sure that it is lighting up.
The upper flipper switch is the shorter of the two flipper switches on the right flipper button
So if both right flippers are firing properly should 2 LEDs light? I think there are 3 LEDs on the flipper board.
Would a little WD40 work or is that a big no no?
