KidVidiot
Thread Manager
So I have this Naomi shelf that I pulled out of an hs-5 several years ago. It uses the original Sega io board and has the power supply and all other stuff mounted on it (as you can see).
I want to put it in my big blue cabinet where I run a jamma 2-in-1 switcher, currently home to SF2:HF and Xmen vs SF.
Is it possible to jut drop it in as is? Or would the better path be to get a Capcom IO instead? I like having the dedicated power supply for the second board, but would I run into problems as far as sound output, etc?
