NEW Naomi Question
fussygamer65
Ringgold, Georgia
I have a Jamma wire cabinet and a Naomi system I would to install. Is there a way to make my Naomi work in a standard Jamma cabinet? Any help would be greatly appreciated.
Yup, you'll need a set up that looks pretty much like this:
What the doodad in the pic that displays the game name? A Pi or something similar?
Yes, it's a RaspPi with a "Pi Plate" lcd. The RaspPi holds the roms and you just scroll through the games.
https://learn.adafruit.com/adafruit-16x2-character-lcd-plus-keypad-for-raspberry-pi
It sends the roms to the Net Dimm board and then to the Naomi.
There are two types of Dimm boards, a regular Dimm board, and the Net Dimm board with the ethernet connection which is the one needed.
This system is a little pricey to get into, but the games list is kickass!
I see no Pi in either of the pics above... nor a display of any sort. I'm guessing a photo has changed/moved?
Anyway, you CAN setup a Pi to be the "server" for a netbooting Naomi. I use my cocktail/digital jukebox cabinet.... but yeah, a Pi setup works great too if you want to go that route.
FWIW, my NAOMI netboot setup using my cocktail can be seen in this video:
I have a netboot setup. One of these days I plan on building a cab for it or getting a universal cab. I played with it enough to get it where I could load the games wirelessly from my laptop. It's been sitting on a shelf ever since along with a bunch of Crazy Taxi and 18 Wheeler parts which is why I got it in the first place. :)
You can also modify the Capcom I/O with a larger 3.3v regulator so you don't need the larger power supply. The only issue I've had with the Capcom I/O was with analog controls(headache trying to wire up a driving rig,didn't work correctly).
They show up from time to time here and ebay.
Anywhere from $100 to $200.
:D
