This is a custom built Naomi / Chihiro / Triforce Compact Flash GD-ROM replacement drive. It includes the any Naomi1 or 2 game you want (If I have it; I do have most) as well as the security key needed to run the system . The kit will directly replace your GD-ROM drive.
It includes two different power methods as shown to connect to your system. If you have a GD-ROM drive already setup then its an easy swap out to connect this replacement drive since the original GD-ROM power cord will plug directly into this adapter.
If you do not have a GD-ROM setup in your Naomi system and your current setup is a cartridge game, you can replace the cartridge with a NET DIMM board and then use this system.
PLEASE NOTE: YOU MUST HAVE A NET DIMM UPDATED TO 4.02 to use this drive. If you have a net dimm at 3.03 or higher then I can help you update your net dimm to 4.02 either by walking you through it by email, or you can send me your net dimm and I will update it for you for 15.00(return shipping). Please notify before I ship your kit if you are going to need my help updating your net dimm. I can send you all the files needed and the crossover cable needed to do so.
This unit has ONLY been tested with a Naomi1 and Naomi2 system, I have not tested it with Chihiro or Triforce (Game included only works with Naomi1 or 2 system)
NAOMI1 Users must have a new BIOS version to run this setup. I can sell you an EPR-21577G(or any other region you want) BIOS chip for 10.00 extra. (Version D and E will not work, of any region). Naomi2's came out with newer BIOS files that can handle it fine.
Extra Games are 25.00 shipped and I have just about every Naomi1 or 2 game.
Adapter itself is 180.00 shipped in US
I also have a Net DIMM upgraded to 4.02 for sale if you need one.
Video of it working -> http://www.youtube.com/watch?v=LJPb2BhBsVA
