I pulled a Nanao monitor out of a virtua cop, then reconfigured the mount to go into a Golden Tee cab. Its not a perfect fit but it goes in there.
The monitor is all connected up save for one thing and it looks flopped onto it self vertically and horizontally right now.
This Nanao monitor has an addtional 6 pin connector on the chassis labeled x and y, and the was a 3pin in the VC cab that was connected to this. One cable looks like it is a ground, and the other was coming from the Power supply(?voltage). I assume this was for orientating the monitors in the sega gun cabs.
hat I need to know/verify is what those 6 x,y pins mean on that chassis- but most importantly what is the power connections running to it?
