I have a ms8-26su and I'm not sure a cap kit would bring it back to life. I saw a ms8-26 chassis on feebay and was thinking if they were the same i could buy that.
I dunno. The 26su isn't that hard to get running. Is it just dead? Check the fuse and do a cap kit. If it lost vertical deflection, there is a resistor on it that goes bad and causes that...
its dead....and I haven't been able to put a meter to the board yet. I know the power supply in the cab works because I put a gauntlet DL board in it and it played blind.
Well, the 26su is a 100v monitor - if it's like mine - so make sure you're not putting 120 into it - if yours is also a 100v. I know some Nanao's were made for 120...
