Nanao MS9-29SU yoke impedence ????
tg2051
St. Pete, Florida
I just got in a Nanao Ms9-29SU... was told the tube was bad... when I went to put the chassis back on it I found the connector had been cut off the brown/gray yoke wires.
The readings I get are as follows:
Red/Blue ->> 0.8 ohms
Brown/Gray ->> 8.0 ohms
Anyone out there know the correct yoke ohm readings so I can compare before installing a new 2 pin conncetor on Brown/Gray and firing this up???
NOTE: Please don't reply with information about one pair being vertical and the other horizontal and that one should read much higher than the other... this is all stuff I know well.... I am looking for the SPECIFIC specs only.... preferably for both pairs... but Brown/Gray only will do if you don't have red/blue. Thanks a million $@-@$
