Nanao MS8-26SU location of c430 on chassis
Deadpool66
Minnesota
Last cap and I cant find it I see the number on the board but there is no location only one cap left on the board and the value is wrong. Anyone got a picture or diagram.
If I remember, the last one I did was similar. One cap wasn't populated, and another was present with a different value. Just replace that other cap with the same value and be done...
Yeah it was weird there was c430 on printed on the board but no place to put it. I didnt replace the last cap becuase I didnt have one that matched the value. Fired the monitor up and it looks good.
Bumping an old thread, adding new information for future visitors.
C430 is not a location to cap.
Total of 31 caps, if replacing C437(120uf 50v) and C905(680uf 200v). Most cap kits do not include these, so should have 29 caps.
Cap Map now available for the Nanao MS8-26SU.
Cap locations marked in red, are typically found in the pre-made cap kits, cap locations in orange are typically not included in pre-made cap kits.
Cap Listing:
C332 / 10uf 250v / located on neck board
C401 / 1uf 50v
C420 / 1uf 50v / located on IC board IC103
C422 / 470uf 50v
C431 / 33uf 100v
C432 / 33uf 100v
C433 / 10uf 25v / 10uf 100v was installed on the chassis
C437 / 120uf 50v / not included in most cap kits
C451 / 100uf 50v
C452 / 1uf 100v
C454 / 47uf 50v
C501 / 1uf 50v
C521 / 33uf 16v
C522 / 47uf 16v
C532 / 1uf 50v / located on IC board IC103
C537 / 4.7uf 100v
C561 / 10uf 100v
C563 / 1uf 50v
C570 / 22uf 160v
C572 / 47uf 16v
C573 / 470uf 16v
C574 / 10uf 50v
C576 / 470uf 16v
C579 / 1uf 50v
C905 / 680uf 200v / not included in most cap kits
C906 / 100uf 200v
C908 / 47uf 25v
C909 / 22uf 160v
C910 / 220uf 50v
C912 / 220uf 35v
C913 / 220uf 35v
