Luddite
I have a Nanao MS8-26SE monitor and the horizontal needs to be wider.
I have adjusted the width coil with a plastic tool and the size only increases a very small amount. The width coil core turns just fine and it isn't broken.
I read that there was a jumper right behind the flyback that you can change from Narrow to wide. I found the jumper and moved it but it made the vertical wide... not the horizontal. I don't see another similiar jumper for horizontal.
Any ideas of what I should try next?
