I have 2 each of the Kaga Denshi flybacks for an early style nanao monitor. I believe these will work for the MC-2000-s chassis. These flybacks are no longer available as far as I know.
The 2 part numbers I have are MSH-D501 AND THE MSH-D548 The first flyback is for the 14" version and the second is for the 20" version according to a post by Jomac. I have included his text for your perusal.
"Also note the Sega MC-2000-S , this chassis was never made by SEGA , it is an early Nanao chassis made by a sister company of Nanao called Kaga Denshi The correct model number is KZ-20EN-L this used the standard 12 pin neck board.
They also released a 10 pin version KZ-20ES that was later replaced with a Nanao MS7-20L .
There is another chassis ID'd as Kagi , this is almost correct but is actually one of the very first Kaga Denshi chassis , they also were a standard 12 pin type , the only difference between the 14" and 20" version was the flyback , 14" flyback was MSH-D548 and 20" was MSH-D562 , this chassis was replaced by the later KZ-20EN-L also known as the SEGA MC-2000-S and are interchangeable.
At the same time a korean universal replacement was made and badged as "Orion" , the first revision was an OC-2021 and later the OC-2022 , over 300,000 of these were sold in Australia alone as they were very reliable and only 1/5 of the cost of the Jap monitors ( Kaga / Nanao / Sega )
It's very handy to note that the KZ-20EN / Mc-2000-S will work on any 13 /14 / 19 inch CRT that the neck board fits on , for example Mitsubishi , Toei , AWA , Phillips , Orion , Kaga Denshi and various older CRT's used in cocktails that have the same neck pinout."
Photos of these flybacks are available here:
http://picasaweb.google.com/pat.danis/Flybacks?feat=directlink
Flybacks are $40 each + shipping. Let me know via PM if you are interested. I have no reason to believe these flybacks won't work but ultimately it is up to you to confirm their application.
