nanao dual 8 (ms-8 25") screen size flickering
Can you verify the game pcb works 100% with another known good monitor? If it works than look into the monitor
From wiki.arcadeotaku.com/w/Nanao_MS8-29. The link also has schematics for 25" and 26" models, so hopefully the diagnoses are the same for all models. Does any of this help?
Repair
Looks like sync has gone but clears after a while or after repowering, also may encounter some size issues
Change C911 C913 C442
Poor colour definition with brightness issues, sometimes intermittent
Change C332
Monitor does not power up or cuts out
There are many reasons for this, here are some that I know of:
Check the fuses first
If you get a line across the horizontal and then the chassis shuts down then there is a fault on the vertical deflection circuit
Signs of frame foldover
Change C433 R433
If full vertical frame collapse then also change R436 Q401 Q402 C437
anode cap was coming off, that's what caused the image size flickering! so now I know what happens when you remove an anode cap from a crt while it's switched on :)
