Namco V147 Position PCB / Gun Board for Point Blank
ReWrite
California
So I am looking at the schematics for PB, and the "J16" that has both gun pinouts isn't on my Position PCB anywhere, I just have J1, J2, and J4... Trying to hook them up to my Recoil SF-X guns, but can't figure out where J16 is since well, it isn't on there.
http://arcarc.xmission.com/PDF_Arcade_Manuals_and_Schematics/Point Blank.pdf
Can anybody help me figure out where to wire up my guns? This is the board in question.
Never seen the game in person but... that J16 is on the filter PCB, not the position PCB. You may be missing boards from your boardset...
Looks to me like if you want to bypass the filter board, the guns would connect to that big 15-pin connector. The pinout is given in the diagram in the back of the manual.
Ah-ha. Well I'll give that a go and see where it leads. Thanks for pointing me in the right direction.
Also, does Opto on the gun go to Sensor or Lamp on the PCB?
Good question. My gut says "sensor" but I think you should figure out the purpose of LAMP1/LAMP2 just to be certain. Does the game have an outputs test? Does it say anything about a light on the guns themselves? I think you need to sit down with a multimeter and do a little prodding.
