Namco System Super 2 quick check
t153
Zurich, Zurich, Switzerland
System Super 22 of course... sorry for the typo... I just want to quick check if some of these systems (Cyber Cycle, Prop Cycle and Time Crisis), are comming up and video is working before putting the PCB's on the shelf for a while. Would applying power to J1 and Video to J9 be sufficient to check (e.g. getting video) or are other connections necessary to fire them up?
for testing video, power and rgb enough for test, you could also patch up the sound connector to speaker.
if there's I/O problem, you could check up those filters pack.
thanks, I was just asking because I did put on power on J1 and Video to J9 but screen stays dark... I think also there's no sync signal - there's no reaction on the monitor if applied... fried video board perhaps?
system super 22 is easy to check. open up the case so you can see the board stacks inside. there's running led in the CPU board. it should be "running" when you powered it up.
thanks, maybe something forget to connect? I don't have a running light on any board. are you able to help here with a picture of your wiring, maybe with short descr.? thank you.
