I just got a soul caliber 2 systen 246 and when I turn it on it get a screen that says JV Master (2.11) Not Connect
I/o 1 No Connect
I/o 2 No Connect
I have a system 246 jamma IO connected, do you think its bad?
Ive flipped the data cable over and tried that with no luck. There is a LED lit under the test "warning" also?
I ve adjusted the power al over the place to see if the LED would go away but it doesnt, it either flashes at low voltage or stays lit on higher voltages.
I/o 1 No Connect
I/o 2 No Connect
