Namco System 246 - Game Settings NOT Saving
ticster
Cambridgeshire, United Kingdom
I have a Namco 246 system with Tekken4 and Soulcalibur 2 - I have the dongles for both games and the additional memory card for Soulcalibur 2. However if I go into the game settings menu - by flicking switch 1.
I can set up the game how I want it to be, go to Exit and Save, press player 1 button and then the game restarts BUT the game still has all the default settings not the ones I set and then saved for instance I set it to Free Play and it comes back with Free Play set to No.
Is this a problem with the dongle/memory card?
Also if I turn off the machine and remove the memory card/dongle I am assuming I should expect all the settings to be retained?
Any ideas??
I actually have a similar issue on my Soul Caliber 2. I can change the settings and they will take effect but when I come back the next day my system is back to defaults? I have both the memory card inserted into system.
Does anyone know why this is happening? and how I can fix it?
Not sure if it uses battery backed ram, but have you tried keeping it on for a few hours and then changing the settings. I have to do that on my Triforce and NAOMI systems to keep the DIMM battery charged.
