Namco system 1 U1 EEPROM corrupt
ifkz
Texas
I got myself into real trouble with my Splatterhouse board. I was looking around for a connection problem that made my sprites perfect while the board was running. I flexed it too far, and the board stack separated. It is now giving me an EEPROM error code.
The chip at U1 is an EEPROM. SEEQ DQ2816A-250
My EPROM programmer can actually write this chip. Where can I find the code? It is standard among all system 1 games.
Or did I just kill my rare/expensive board, sniff...
You don't need to write any code to that chip - just place it into your programmer, select the correct chip type and erase it.
Better still, just put the boardset into test mode and see if that helps. If not, just erase it.
This fixed it, repair log to appear shortly!!!!
