Namco Assault questions...
Robran68
Fraser, Michigan
I just picked up one of these and it's got a couple issues. First it seems the controller sticks are really sloppy, are they suppose to be that way or does the assembly wear out on these? Also seems that the resolution is not as high as it should be, seems to be missing some detail. Example is when you look at the attract mode title screen the red seems to be more like lines of different color rather than a smooth transition of red. All the colors seem to be there and it has the original EZ Sanyo with a good picture.
Just bought RAM controls Logo rebuild kits for the joysticks so that should fix that problem.
Thanx Dave!
do you want to sell the other sticks? Did you get the monitor problem fixed?
I'm rebuilding the set on the game, I didn't buy new sticks. I think Dave is going to repro the whole stick though...
Didn't get a chance to mess with the monitor yet. It almost looks like the colors are in 8bit and are suppose to be in 16bit or whatever the resolution is on this game.
I've had trouble with the left stick being loose and the right stick was tight and responsive. Now the right stick is getting stuck a lot and is hard to control. Might need a rebuild or something soon. Anyone have a quick fix for a "sticky" right-hand stick? Certain places I should put 3-in-1 lubricant or something? Thanks.
