My Tron Light Cycle Mod Done - and a Question
PensFan66
New York
OK, I was pretty excited to get this done and working well - I only have Sams Light Cycle and Clu's is on the way - I used the Hallmark Cycles since they are a good size, they arent too big like the Toys at Target and these are even more detailed than the included cycles.
I dont ever want to cut or drill anything on the cabinet, so this mounts up the existing screws for the included cycle. I wires to 5 volts in the header so it stays lit, after modding up the switch in the Hallmark Cycle.
Thats my main question - I would like this to light with the GI so it will go off between balls / etc ..... Can anyone point me in a direction for a connection that will do this? The cycle can use 4.5-5 volts - maybe alittle more, but Im not sure. Im using a 5 volt connection now that I built a connector for.
