mecha
my Sanyo 20-Z2AW came up all green after capkit -- any idea why?
for whatever reason, Bob sells the standard kit for the 20-Z2AW, and for what it's worth, it was enough to fix the squishing problem I had at the top of the screen. I don't know where the 20-Z2AW places in terms of it being higher or lower end compared to the EZV, but with the degauss button and inverter board on my PC-10 I would think it would be a little more deserving of a deluxe kit, unless the rest of the caps do in fact run different values than the EZV.
the part I didn't get however was after I capped it and reinstalled it, only green came up, it looked like an Apple IIe monochrome screen.
no degree of adjusting blue or red bias made those show up. after powering it down I switched the top monitor signal to the bottom monitor I capped, and all I got was some red dots on the screen, powered it off again, hooked everything back up the normal way and uh, red green and blue all worked, albeit the white balance was off since I messed with the knobs. (I fixed that)
so... any idea what happened?
