Arcadenut
I think I need all 4. If I don't then I'll send you one.Want to sell me one of them?
I hadn't looked at my monitors yet to see the practicality of it, but I was also thinking of 3D printing something because the cardboard is not all that durable. One of mine has split cardboard. If you do it, be sure to post about it please!I'll take them.
I'm working on getting one of these monitors and I am going to look at 3D printing a box to hold it.
I'll probably make the files available if I do it.I hadn't looked at my monitors yet to see the practicality of it, but I was also thinking of 3D printing something because the cardboard is not all that durable. One of mine has split cardboard. If you do it, be sure to post about it please!
Since 3D printed frames came up here, I wanted to share the frame I designed and printed. It was kinda tough because the length of the cardboard box is greater than the dimensions of my print bed (ender 3), so I had to shorten it as much as possible, down to 232.9mm. Even then, I wouldn't have been able to print it with stock firmware. I've installed marlin, customized to print to the extreme edges of my bed and this print literally uses the full width to the point were an extra 0.5mm would mean printing off the left and right edges of the bed. The frame barely extends past the pcb and neck board, so I couldn't make it much shorter than it already is. I could've printed upward to give a little more breathing room but decided this was the best way for me to go overall. I'm pretty happy with how it turned out.I hadn't looked at my monitors yet to see the practicality of it, but I was also thinking of 3D printing something because the cardboard is not all that durable. One of mine has split cardboard. If you do it, be sure to post about it please!
That looks GREAT!Since 3D printed frames came up here, I wanted to share the frame I designed and printed. It was kinda tough because the length of the cardboard box is greater than the dimensions of my print bed (ender 3), so I had to shorten it as much as possible, down to 232.9mm. Even then, I wouldn't have been able to print it with stock firmware. I've installed marlin, customized to print to the extreme edges of my bed and this print literally uses the full width to the point were an extra 0.5mm would mean printing off the left and right edges of the bed. The frame barely extends past the pcb and neck board, so I couldn't make it much shorter than it already is. I could've printed upward to give a little more breathing room but decided this was the best way for me to go overall. I'm pretty happy with how it turned out.
I talked with him. He can. Any chance you can send it direct to me via email (if that's possible, I don't know how those things work)? I'm supposed to stop by his place on Monday.I don't mind publishing it but just make sure your friend can print something that's 233mm long. That's probably too large for many if not most consumer printers. Might be a few days before I can get it onto thingiverse.
Joe (joemagiera at ameritech dot net)
[email protected]
Sweet! Thank you very much. Hopefully I'll have a nice cage for mine soon.Uploaded and documented on thingiverse. I'm sure he knows how to work with thingiverse so you could just give him the link. Or you could download the files from this link yourself. You'll want to read the documentation there for required hardware and whatnot. LMK how this works out for you!
Samtron Monitor Frame by theshanman
The little samtron monitors that come in cardboard frames could use a sturdier frame, so here it is. Designed to mount the PCB on the bottom, with openings for the adjustment knobs on the right side and an opening for a cdjump adapter board for arcade compatibility.The back is optional but it...www.thingiverse.com
3d print file for the back please?Though not essential, I decided to add a back to my monitor frame. Provides a bit of extra protection for the neck board, and it also feels a little more complete this way, even though the boxes these monitors come in don't have a back.
My 3D printing buddy, on his first two printers, they did not like the file. He's trying his bigger printer this week.It's there on the thingiverse page. How did your print turn out?
