Level42
This is a BRILLIANT idea if I may say so myself.
Previously I've been using a heat gun, knifes, putty knifes, wirewheels, sanding discs (loads of them) and combo's of these and it was ALWAYS a struggle.
I had noticed that after my friend welded the 4 studs for the original Pac Man joystick on the CP, the CPO had become loose because of the heat of the welding.
So.....I figured, let's try to heat the CP up VERY hot and see what happens.
It worked out GREAT. In the video you see I can only pull small parts, but this is because it was on an inside bend. The other bigger sides went much smoother. The very big plus is that there is NO glue residue.
Of course you need to be careful, you need an oven-glove to hold the CP and turn on the "air-sucker" to get rid of possible bad fumes, but otherwise, I love this method !
